ANH-1A "DakkaZilla" (3x AC10, 1x LPPC, LFE300)
1 rating
Thread in 'ANH-1A' started by Solahma, Jul 19, 2017.
  1. Solahma
    This is a modification of my original 3xAC10 build. I removed 3DHS and put in a LtPPC because it was running extremely cool even on Tourmaline.
    2nd match in the build without the LPPC, but it would have performed the same if not better.
    You REALLY have to hold your position in this mech an play carefully. It's arm AC10 is very low and will typically hit terrain if you are trying to peek. Rely on the mech's superior Firepower and Durability to win your engagements. Try to take advantage of friendly movements so you're not caught alone or jumped by multiple mechs. It's biggest weakness, as with most assaults, is getting ganged up on due to its speed and size. Just position well, be mindful of your hardpoints, and dakkadakkadakka
    Virlutris and The Verge like this.
  2. Virlutris
    Virlutris Junior Member
    Hey Solahma, would you consider an SNPPC or LPL on this build?
    You'd probably have to give up a lot of ammo or some DHS to do it, so I can see where you might not given that spamming the AC10s is the point of the thing.
  3. Lorgot
    Lorgot Advanced Member
    403
    72
  4. Finally picked up one of these. I like the 2x LPPC build.
    The match is usually over one way or another before I run out of ammo.
  5. Chief YYZ
    Chief YYZ New Member
    This is what I've been running on my 1X, been thinking about buying a 1A for the AC quirk. Only difference on the 1X is the third MPL is in the head, giving you 3xMPL to zombie with. I've never run out of ammo when it mattered, worth noting, with skill tree you get 135 ammo.
    2 tons per AC10 has always been enough for me, I like this too, swap for an ER if desired
    Hate to lose the STD engine, but I'd do this if you have problems with ammo
    And if you really insist on 9 tons
    The speed loss is minimal, and that fully armored LA will have it's ammo used right after the 1 ton in the head.
    Also, on the OP build, you have 7 slots open. No reason not to use Light Ferro and add some armor to the stripped arm.
  6. CarloArmato
    1,967
    586
    @Chief YYZ
    Using your last build as a starting point, you can easily fit a 2nd LPPC for maximum alpha strike. It will become a bit hot, but it should still be manageable. Also, 6 tons of ammo with max skills are worth ~7,2 tons of ammo (and ~1600 potential damage)
  7. CarloArmato
    1,967
    586
    Nope, you can easily fit an STD300 and upgrade to endosteel, so if you lose any side torso you won't have that much of heat loss... But you lose 1 DHS
  8. Chief YYZ
    @Carlo, I mean, my builds are everything except the last build. The last build is just the OP with an obvious flaw rectified. There is free armor just left on the table.
    edit: thought I was pretty clear I only run 5-6 tons for 3 AC10s, my preferred build is the first one with MPLs, and a bigger alpha and more DPS than 2xLPPC, but less range, and not technically PPFLD. I wanna try the LL, I may warm up to LPPCs, but I haven't yet. Pulse lasers are pretty much pinpoint on a DPS build, we'll see what the agility patch brings:
    https://www.mwocomp.com/patches.html
