ANH-2A "Osmium" (1xHGauss, 1xUAC20, 4xMLas, STD280)
Thread in 'ANH-2A' started by Cpt Chattahah, Aug 9, 2017.
  1. Cpt Chattahah
    This is one of the few platforms to pull off a dual HGauss, however, why not go full bore and get a UAC20 in the mix???
    85 point alpha with a double tap of the UAC, decent cooling, and the ever loving speed of an Annihilator. (Jesus these things drag) Alas, 100-tonner armor scheme and massive damage in close range keep you in the pinnacle of brawlers with the Heavy Gauss still dealing effective damage out to the ~600m range. Ammo may need to be adjusted as the HG only has 20 rounds, but you can easily strip some shield arm armor or swap some UAC ammo to keep a little more threat at range. However, with the UAC double-tap capability, I feel 4t of ammo for each weapon system is perfect. This is truly a CQC expert!
    Get out there and crush everyone around as the heaviest element on the battlefield!
    Blagg Zear likes this.
