ARCHER DETAILS FOR 15-MAR-2016 PATCH
Thread in 'Official 'Mech News' started by Blagg Zear, Mar 13, 2016.
  1. Blagg Zear
    by Alexander Garden in [ Announcements ] on, Mar 12, 2016 12:01 AM UTC
    Greetings MechWarriors,
    This post contains information for all variants of the Archer, releasing for eligible pilots with the March 15th patch.
    Archer
    Pictured variant: ARC-5S with standard Loadout and a customized House Davion Pattern
    Release date for MC: June 7th 2016
    Release date for C-Bills: July 5th 2016
    First produced in 2474, the Archer was designed as a long-range fire-support BattleMech that would harass an enemy at range while also causing significant damage in the process. It brought a successful mix of paired Doombud LRM 20s with a bevy of Diverse Optics medium lasers as backup weaponry for close-in work. The Archer was not only a mainstay of the Star League Defense Force, but most of the Successor States produced a variety of variants, building on the impressive original platform.
    Quirks
    Archer ARC-T 'Tempest'
    The ARC-T is the Hero variant of the Archer, and until its in-game MC purchase release date on June 7th 2016 is only available through direct purchase from the Archer page. It features a custom 'Tempest' Hero Pattern and a 30% boost to C-Bill earnings.
    • Tonnage: 70
    • Engine: 280 Standard
    • Top Speed: 64.8 kph
    • Max Engine Rating: 340​
    • Torso Movement:
    • 100 degrees to each side.
    • 25 degrees up and down.​
    • Arm Movement:
    • 20 degrees to each side.
    • 30 degrees up and down.​
    • Armor: 416 (Standard)
    • Internal Structure: Endo-Steel
    • Weapons & Equipment:
    • Left Arm: Medium Laser
    • Left Torso: LRM 20, Guardian ECM Suite, LRM Ammo x2, Double Heat Sink
    • Center Torso: Engine, Medium Laser x2
    • Right Torso: LRM 20, LRM Ammo x2
    • Right Arm: Medium Laser​
    • Hardpoints:
    • Left Arm: 2 Energy
    • Lower Arm Actuator: Yes
    • Hand Actuator: Yes​
    • Left Torso: 1 Missile, 1 ECM
    • Center Torso: 2 Energy, 1 Missile
    • Right Torso: 1 Missile, 1 AMS
    • Right Arm: 2 Energy
    • Heat Sinks: 12 Double
    • Jump Jets: 0 (0 Max)
    • ECM Capable?: Yes
    • MASC Capable?: No
    • Module Slots:
    • Mech: 1
    • Consumable: 2
    • Weapon: 2​
    • Movement Archetype: Large
    • Quirks:
    • +11 Additional Structure (CT)
    • +7 Additional Structure (LT)
    • +7 Additional Structure (RT)
    • +5 Additional Structure (LA)
    • +5 Additional Structure (RA)
    • +7 Additional Structure (LL)
    • +7 Additional Structure (RL)
    • -5% Missile Heat Generation
    • +5% Medium Laser Cooldown​
    • 30% C-Bill bonus
    Archer ARC-2R (S)
    The ARC-2R (S) is a Special version of the ARC-2R, and features a custom Classic IS Collection Pattern and a 30% C-Bill Boost to C-Bill earnings. It is only available through the Archer Collector Pack.
    • Tonnage: 70
    • Torso Movement:
    • 110 degrees to each side.
    • Arm Movement:
    • Internal Structure: Standard
    • Left Torso: LRM 20, LRM Ammo x2
    • Hardpoints:
    • Left Torso: 2 Missile
    • Heat Sinks: 10 Single
    • ECM Capable?: No
    • MASC Capable?: No
    • Module Slots:
    • Mech: 1
    • Consumable: 2
    • Weapon: 2​
    • Quirks:
    • +60% Acceleration Rate
    • +60% Deceleration Rate
    • +35% Torso Turn Rate (Yaw)
    • +5% Energy Cooldown
    • -5% Energy Heat Generation
    • +10% LRM 5/10/15/20 Velocity
    • +15% LRM 5/10/15/20 Cooldown​
    • 30% C-Bill bonus
    Archer ARC-2R
    The ARC-2R is the standard version of the ARC-2R (S). It does not possess the 30% C-Bill boost or the custom Pattern of its (S) counterpart. The Quirks and Loadout are identical to the ARC-2R (S) above.
    Archer ARC-5S
    • Tonnage: 70
    • Engine: 280 XL
    • Torso Movement:
    • 120 degrees to each side.
    • Arm Movement:
    • Left Arm: Medium Pulse Laser, Streak SRM 2
    • Left Torso: LRM 15, Narc, Narc Ammo, LRM Ammo, Streak SRM Ammo, CASE
    • Center Torso: Engine, Medium Pulse Laser x2
    • Right Torso: LRM 15, LRM Ammo x3, Streak SRM Ammo, CASE
    • Right Arm: Medium Pulse Laser, Streak SRM 2​
    • Hardpoints:
    • Left Arm: 1 Energy, 1 Missile
    • Right Arm: 1 Energy, 1 Missile
    • Heat Sinks: 10 Double
    • ECM Capable?: No
    • MASC Capable?: No
    • Module Slots:
    • Mech: 1
    • Consumable: 2
    • Weapon: 2​
    • Quirks:
    • +50% Acceleration Rate
    • +50% Deceleration Rate
    • +35% Turn Rate
    • +45% Torso Turn Rate (Yaw)
    • +10% Energy Range
    • -10% Laser Duration​
    Archer ARC-5W
    • Tonnage: 70
    • Engine: 280 XL
    • Torso Movement:
    • Arm Movement:
    • Left Arm: SRM 4, SRM Ammo
    • Left Torso: LRM 20, LRM Ammo x2, Narc Ammo, CASE
    • Center Torso: Engine, Narc
    • Right Torso: LRM 20, LRM Ammo x2, Narc Ammo, CASE
    • Right Arm: SRM 4, SRM Ammo​
    • Hardpoints:
    • Left Arm: 2 Missile
    • Center Torso: 1 Missile
    • Right Torso: 2 Missile, 1 AMS
    • Right Arm: 2 Missile
    • ECM Capable?: No
    • MASC Capable?: No
    • Module Slots:
    • Mech: 1
    • Consumable: 2
    • Weapon: 2​
    • Movement Archetype: Large• Quirks:
    • +30% Acceleration Rate
    • +30% Deceleration Rate
    • +50% Turn Rate
    • +10% LRM 5/10/15/20 Velocity​
    SOURCE: http://mwomercs.com/news/2016/03/1496-archer-details-for-15mar2016-patch
