designed as a all rounder this build is designed for the ATLAS mindset, cause who are you kidding your the slowest, biggest target on the block. Knowing this this mech reaches out to other mechs at a distance with the ER-Large Lasers, as they close in as they will always do you pound them with the AC-20 and MLs and continue at close range by adding the SRM's(or SSRM's) to the latter weapons bracket. The AC-20's got plenty of ammo so no worries there and heat is manageable.
