This is the build I use on my Atlas K3. I call it Justin Nuff because it has "just enough" of everything: firepower, armor, movement, ECM, heat dissipation (if you're careful). I average 2-3 kills a game, with 7-800 damage and around that much damage absorbed. I find it's best played by hitting from odd angles using the JJ's and ECM then fading to do so all over again. If you get lucky and catch another mech solo, don't hesitate to burn it to the ground. https://mwo.nav-alpha.com/mechlab?b=fbbad23d_AS7-K3 My skills loadout: full heat gen all three missile skills full skeletal density full armor hardening full reinforced casing (with the Atlas' built in minus to be crit that's -72% to be crit. I know it's multiplicative not additive, but they are still going to have to kill you the hard way.) full vent calibration Improved Gyros 2 pts. full cool run full heat containment full seismic sensors full enhanced ECM double coolshot with coolshot cooldown 2 points into Adv. Salvos
