Casual AS7-K3 "Ma Bell" (2xBinary Laser, 2xLLAS, ECM, MAX armor, 3xJJs, Endo, DHS, Std325)
Thread in 'AS7-K3' started by Pachyderm, Aug 26, 2023.
  1. Pachyderm
    Pachyderm New Member
    https://mwo.nav-alpha.com/mechlab?b=3fbdd58e_AS7-K3
    "Reach out, reach out and touch someone." If you know, you know. This build has steady, consistent firepower aided by ECM and maxed out jump jets for mobility usually unseen in the big boys. You can effectively alpha 6 LLAS twice with a short pause between for cooldown, or cycle them in left arm/ right arm mode for longer. It also has the usual slab like armor of the Atlas when properly skilled defensively.
    Skill build I use: a085a934a36d9d6569e4bffff6f000000000020468466125b2fb698000000
