Group 1 3x ER PPC Group 2 1x Gauss Group 3 2x SSRM2 Toggle Group 1 to Chain-Fire after couple of Alpha or when engaging in brawl Okie Dokie... Exact same build, but with AC/20 instead of Gauss, slightly more armor, and a lot more heat on separate entry per Admin request. AS7-RS Ungainly Sniper 2
This is essentially two completely different builds. Please separate them into their own build sheets so that people can vote for one OR the other.
what is the point of the streaks? you do most damage with direct fire, and any light mech fears ERPPC's ATM. just my 2cents.
Ungainly as in asymmetric weapon placement, or just rather slow? How about this as a possible alternative? Not quite the same sledgehammer of a direct-fire Alpha at range, but it will still knock off over a ton of standard armour per strike. The added Beagle Active Probe will improve the lock on time of the SSRMs. Armour rating is up half a ton and the mechs speed has improved by approx. 8kph. I also shifted the SSRM ammo into the RT. Hope this helps. Happy hunting!
Slow and asymmetric. Streaks are their to dissuade lights and I like the 3 ER PPC with Gauss for Initial Alpha strike and then chain fire ER PPCs with individual Gauss rounds for when heat needs to cool off.
