Everyone's favorite zombie (ghoul) from Fallout, GOB! With 3 MPLs between the CT and Head, this is an extraordinary zombie build. I haven't played an AWS in a couple years, but, last night I decided to mess around a bit. I loaded out with MPLs, loaded out DHS, threw in the biggest powerplant I had within weight, and had some tonnage for an SRM4. It's basically a medium/heavy build, but, with 13T of armor and still moving at 80kph. Quick enough to get to a fight and lay down some significant pain, solid twist rate (needed with the barn door), enough armor to stick around (Structure +10 to ST, +20 to CT), and can tank like a boss without ever being disarmed until they pry your Pulses from your cold, undead corpse!! Weapon Quirks: ENERGY RANGE: 12.50 % ENERGY HEAT GENERATION: -12.50 % ENERGY COOLDOWN: 15.00 % LASER DURATION: -15.00 % All in all, a fun build for a rarely seen chassis. If you haven't sold your Awesomes off by now, whip 'er out for a spin and have some fun in a classic! Cheers.
https://www.mechspecs.com/threads/aws-9m-gob-1x-srm4-6x-mplas-std360.9800/ I use only pulse in my build
