BAS-A 'Silent Hunter' (2xcGauss, 6xcERML, cECM, 1xJJ)
1 rating
Thread in 'Blood Asp Omni Builds' started by Aylek, May 16, 2018.
  1. Aylek
    This is the ECM version of my classic & proven 'Hunter' build on the MKII Deathstrike. The build looks pretty sweet in my Mechlab with no less than 4t ammo and several additional DHS.
  2. Gun Tuv
    Gun Tuv Well-Known Member
    115
    I did inviso-deathstalker with the other ECM one - more room for support gear, though ofc a bit of jumping is nice I preferred DHS/ammo/etc. Either way, it's a monster.
  3. Aylek
    Smurfy link added.
  4. Gun Tuv
    115
  5. CarloArmato
    1,192
    362
    165
    Very solid build: don't drop without maxed ECM skills, you will be missing a lot of potential.
    It doesn't have the speed, cooling and hardpoint locations of a death strike (ERML are low), but ECM greatly helps to achieve free trades at range with gauss only (which are very high) and shooting a full alpha before someone notices you are a deadly threat makes this build really worth a try. 6xERML should be used only when targets are in optimal range or you have been discovered.
    I'm personally using a "B" variant without JJ because it's not really worth it, but any ECMed variant will be fine.
    Aylek likes this.
