_ High ballistic hardpoints for hill or side poking at about 700 meters. Typically you should be able to get a lock pretty easy when holding the UAC5's on target. If you want more ammo or armor, drop Artemis. ...Or you could drop two tons of ammo and put two ATM12's on the mech instead of LRMs. Also, what the hell happened to the left torso LRM20?
_ You can fit 3xLRM15, but it feels a lot hotter. I had to back off on using the UAC5s. You could also put the LRM 20s in the arms if you don't have the hero LT omni and have a bit more balanced build. _
Yeah you're going to get ghost heat with the LRM15s. That'll kill your heat efficiency for not much gain
