Casual BAS-Prime 'Heavy Shotgun' (2xcLBX20, 2xcHLL)
Thread in 'Blood Asp Omni Builds' started by OrosTheAvengerX, May 22, 2018.
  1. OrosTheAvengerX
    OrosTheAvengerX New Member
    A mid to close range fighter with asymmetric laser stack for convergence and shielding reasons. Could also be built on the B variant for ECM, but I do not really want to spare the tonnage for it.
    Gun Tuv likes this.
  2. Excalibaard
    5,278
    Hey @OrosTheAvengerX ,
    Welcome to MechSpecs! As you've probably noticed in the threads around yours, it's expected that you give a summary of your build in the title. This is to make searching/browsing easier. It's explained in detail here: I've changed your thread title this time, but please take care of it yourself in the future!
    Cheers,
    Excalibaard
  3. IronEleven
    IronEleven Active Member
    I run 2 tons more of ammo on my dual LB20 builds and still have problems with running out.
  4. OrosTheAvengerX
    Updated op in line with mechspecs preferred format.
  5. Excalibaard
    5,278
    Appreciated! Looks like a devastating build, though I'd get at least 1 more ton for the LBX20s. Armor can be stripped from the LA because it's not a very good shield arm profile and not being used for anything else. It'll be the first ammo to be consumed so there's little chance it'll be destroyed before we can use it too. also removes dangerous ammo explosions from our CT :)
    Gun Tuv likes this.
