BJ-1DC "Gambit" (1x Gauss, 1x ERLLas, 2xSMLas, XL225)
Thread in 'BJ-1DC' started by B0ilz, Jan 6, 2015.
  1. B0ilz
    B0ilz Well-Known Member
    210
    62
    Although I'm still grinding out the credits to completely build this, just through simple math it has some pretty interesting features.
    With the 20% Ballistic cooldown quirk:
    Gauss goes from 4.00 seconds to 3.20 seconds.
    ERLlas is 3.25 seconds.
    Almost perfectly in sync with each other. If you lead your target and use the ERLlas as a laser pointer of DEATH, you can charge your Gauss at the same time, and release it almost at the same time as the ERLlas shuts off. If you're REALLY good, you can time your mouse clicks so that the Gauss charges only after 0.5-0.6 seconds the ERLlas is fired, therefore allowing you to not waste any of the ERLlas damage, and still allow some room to fire the Gauss where you want. Additionally, the cooldown of both weapons is extremely similar, allowing for easy repeats of the process above.
    Smlas are just for close range support.
    Feedback is appreciated! :)
    AMS version if you are either scared of Lurms or think those Smlas are useless.
    Left hand version, for the sake of my left-handed friends :D:
  2. rurik
    rurik New Member
    Interesting build... but there is an issue about this combination... ERLL will reveal your position... while the Gauss rifle is almost untrackable.
    what i do.. is to get Gauss, a MPL and 3 SPL... then, once you are bitten, you can return it back
  3. Motörhead
    Not a bad idea but given weapon modules I don't think it's worth to go FF just for that single MPL, so this is how I build it:
    So I can equip radar/seismic/gauss cooldown/spl range and cooldown.
