this mech is my pride and joy, i love playing it and have so for over 600 games and counting. it is very good at assassinating other mechs, and on most maps it will do 2 alphas in a row for a wopping 104 damage and almost no risk for long range and DPS use the 2 LPL's (on forest colony they can fire 20 times before the mech overheats) the general tactic is pop up 2 times from the ridge and alpha somone (the sismic module prevents any unplesant suprises) then relocate (ore atleast cool down ) the sismic module will prevent u from being ambuched wile the radar dep will prevent you from geting retalioratery lrm's oder modules are LPL range and ML range ps the placment of the lasers helps a lot so chek them my blackjack stats (bear in mind this was my first mech) BLACKJACK BJ-1X match 611 wins 326 losses 281 ratio 1.16 K 648 D 420 ratio 1.54 damage 240,824 xp 622,311 time 2 days 07:39:27
It's kind of depressing that this build is like a better range version of my Gargoyle build (the MLas over ERSLas at least), and does the same damage at half the weight, with more speed. LPLs are always nice too, if you're caught in a snipe fight, you can easily still poke out and put in some nasty hits.
do you own a BJ-1X? you have to try this build its realy fun to use, you do need to have it masterd do ore the heat will be inposible to manage, i find it best to alpha 1 at the start of the mach see til where the heat go's suptrackt that from a 100% and never alpha when your heat is over that. but when its fully masterd you should be able to do 2 succesive alphas on all maps (use overide in some) but thera terma tormaline and caustic.
