Black Widow "Clanbuster" (2xUAC5, 2xLL, 2xML, XL300)
3 ratings
Thread in 'Black Widow' started by Crucii, Jan 20, 2016.
  1. Crucii
    Crucii Junior Member
    A classic. This one was already good in the CTF-3D and is even better in the WHM-BW.
    invernomuto and Aylek like this.
  2. Aylek
    Confirmed. This is a pretty beasty build.
  3. Aylek
    606k CBills. In a PUG drop. Guys, you need to test this thing for yourself and RATE IT. Sadly I alone can only give it 5 stars and only once.
  4. Furuta
    Furuta New Member
    This is the best set up for this mech. I tried all the other builds and got nowhere near the damage this beast puts out. Thank you so much for this build.
  5. Arcturus Kerensky
    Arcturus Kerensky Star Lord
    31
    How are you guys setting up your weapon groups?
  6. Aylek
    1 / left mouse: MLas (grouped)
    2 / right mouse: LLas (grouped)
    3 / mouse thumb: UAC5s (grouped)
    4 / mouse thumb 2: LLas (chained)
  7. Arcturus Kerensky
    31
    thanks Aylek...looking forward to giving this a go.
  8. Aylek
    You're welcome.
    Some gameplay tips on this:
    - Basically you want UACs and LLas at range and UACs and MLas at close range.
    - Mix in the LLas if needed, but watch your heat if you don't have a chance to cool down a bit afterwards.
    - With only 10% CD and no reduced jam chance the UACs still perform very well here, but obv will produce a lot of heat if not jamming and double-tabbed quite a bit. So watch your heat while excessively spamming those (see previous tip).
    -Try to use lasers only for fighting light mechs harassing you and save your ammo on the UACs unless you're either totally desperate or sure to hit your target.
  9. Arcturus Kerensky
    31
    Excellent build. Great at both long and short range engagements
  10. Flokoloko
    This is also a good build for the 6R (for those who dont own a Black Widow) with high hardpoinst for all lasers but slightly worse quirks
  11. Excalibaard
    5,247
    On a three button mouse I'd group them like
    LMB - UACs
    RMB - ML
    "3" - LL
    Easy access to double tapping UACs and brawling weapons without impairing movement is key!
  12. Aylek
    Yeah, I changed my mouse settings on this one when coming back to this build recently.
    1 (LMB) - LL grouped (easily switchable to chain fire by quickly hitting Backspace)
    2 (RMB) - UACs grouped
    3 (thumb 1) - ML grouped
  13. invernomuto
    invernomuto Junior Member
    31
    Possibly the best build for this mech!
  14. Aylek
    Loosing the Ballistic Cooldown quirks was quite a hit, though. :-(
