BLR-1G "Epy's Alphamaster Version 2" (3x LPL, 4x ML, XL390)
Thread in 'BLR-1G' started by Epydemic2020, Mar 14, 2015.
  1. Epydemic2020
    Epydemic2020 Well-Known Member
    115
    I felt like this mech was different enough to warrant a new post. If the ghost heat becomes permanently removed from 3 LPL, this mech will be very effective. Honestly I will run it this way even if the ghost heat is implemented again.
    20 DHS, a 53 damage alpha, and an alpha that only brings your heat up to 37% is a pretty nasty combo when you can run at 81.8KPH
  2. Cpt Chattahah
    Checking things out, I would say the best way to brawl around with this and still have some speed would be with a STD360, 3x LPL, 3x MLas.
    With the quirks, the cooling should be very manageable. 48pt alpha with quick duration due to quirks. MLas range matches LPL range... solid build for a ranged brawler. I dig it! Must test tonight!
    Go STD350 for a little more cooling if you don't mind the speed...
    schnaetz likes this.
  3. schnaetz
    schnaetz Benefactor
    247
    If you really want to go with an XL, try exchanging one LPL with a LBX. This adds some serious crit and takedown potential to this mech and uses the ballistic quirk
    (made this build ages ago: https://www.mechspecs.com/threads/blr-1g-wubcrit-1x-lbx10-2x-lplas-4x-mlas-xl375.5102/).
    Or with 3x LPLas:
    But today, in a world full of clan laser vomits and heavily quirked IS laserboats, I don't use a XL on the Battlemasters anymore (except LRM boat). Your STs get cut of in no time, especially if an opponent notices that you move quite fast for an assault...compare that to a Timberwolf (heavy mech!), which is somewhat of a benchmark when I try to think of laser builds.
    That's why I prefer the STD version of Cpt Chattahah, the longer you live, the longer you will be doing damage . Also, ~6kph is a tradeoff I'm willing to accept in an assault mech, that has to brawl from time to time.
    epikt and Aylek like this.
  4. Epydemic2020
    115
    For you Standard Engine Fans:
  5. The Verge
    Made a few changes to the weapon placement for the STD engine.
    I'll be testing this
    Epydemic2020 likes this.
  6. Excalibaard
    Will try the STD325 version. Asymmetry works better than the build above I think.
  7. Excalibaard
    The civil war tech way I'd like to build it:
    Aylek likes this.
  8. Gasboy
    Gasboy Advanced Member
    291
    57
    May I suggest ERMLs? The difference in heat is 0.03 per laser. They go very nicely with LPLs.
  9. Excalibaard
    The heat difference is 1.1 per laser (and HPS is about 25% higher), but you could do it for the range alignment.
