Boar's Head "Heavy Ranger" (4x PPC, 2x ERLLas, 1x MG, XL385)
Thread in 'Boar's Head' started by Novarum, Jan 18, 2014.
  1. Novarum
    Novarum New Member
    I wanted to make build which could mount a bunch of high damage, long range lasers slot weapons and have enough heat sinks to allow for a decent bombardment. This is what I came up with:
    Even with 18DHS, it runs molten hot in sustained fire. User beware.
    I put a machine gun on there for laughs. If you get attacked by a light when your alone, you could potentially rip their armor with the LLs and dps them with the machine guns. But if one was to run this, I'd highly recommend staying close to teamates to avoid that senario all together.
    For best results, put both arms into a chainfire set. That way, you can effectively peak out and cover fire with each arm as well as not have to worry about ghost heat when firing both sets.
    Criticisms or needed changes?
