Not so cool, not so fast, but the damage that this boy can spit out is wow mouse 1 is 4srms4 mouse 2 is 2srms4 + lbx10 due to the the lbx10 shorter cooldown, i usually only place srms 4 cool down in order to sync them. btw ammo wise you need to sync it together to avoid having one of the weapon ran out of ammo while the other still full of it but not fast enough to spit it onto the enemies But it all comes down to what you want and how short do you want the pug match to be. you wont need alot of it as far as i concerned for the lbx10 1 and half ton of lbx is enough for 30 shorts, while the 4 tons of srms are only enough for you to fire 16 times, thats 32 times if you seperate them (by 4/2 srms4 or 3/3 srms4) since firing 6 srms will get you ghost heat.
Ohhhh damn, I actually came up with the same build last night! Looks beastly but definitely requires some patience to maximize its usefulness.
I like it, feels dirty throwing that kind of damage down in such a beefy chassis Did find it too hot for my tastes so I tried a modified version out With lighter Fero and the 4 SRM 4 Artemis theres a little more weight for a larger engine, option available to strip the two half tons of SRM ammo for an engine mounted heatsink if prefered as you can fire all the SRMs at once without ghost heat. I did find myself running out of SRMs without the extra ton, but with Missle Rack skills it's a little easier
