_ Notable quirks: 15% ballistic cooldown (AC10 cooldown will become 2s like SRM2's cooldown) -5% missile spread (further enhances good SRM2 spread) The concept behind is actually very simple: AC10 only at range for opportunity shots and/or softening up targets 5xML are your alpha with high heat . Use them whenever you are cool enough to use them, because if you don't fire those 5xML, you are completely heat stable. AC10 and SRM2 has very similar cooldown and should be fired togheter during a brawl. So, in the end, you either have a heat stable DPS machine with a hot alpha damage for poking or when starting a push. If 5xML doesn't look very suitable for brawl, then have a look at the alt with an XL engine and MPLs _ Very hot, but like I said early, using LBX10 and SRM2s alone you are heat stable, so MPLs are your best additional high-alpha / high pinpoint close range. XL engine shouldn't be a big issue because your CT is actually bigger than you think, plus you can easily shield one side by twisting properly. Due to shorter range and higher heat, it is more suited for close range quick "assassinations" rather than sustained entrenched fights mid range.
Hmm interesting! I've just discovered the Champion this week and I'm liking what I'm seeing. Reckon I'll be needing a couple of variants at this rate.
