...with a nail gun. good for some high quality pug memes when life's got you down and only weird internet culture can sustain your existence. 60 murms is also possible, but you should ask yourself if it's worth it and then ask your parents permission to handle such fragile dreams. You could do an LE250 and remove the DHS for more ammo but this is slot efficient and has shield arms so you can take/deal some more punishment before inevitably dissipating into the void. A STD engine version for people who didn't have the luxury of buying non-standard LE yet:
I guess a kintaro will do, but I made it specifically because my AH is collecting dust while it has a c-bill bonus modifier without owning any kintaros Also, with the plentiful missile hardpoints it may be more interesting tonnage-wise to mount multiple MRM10s instead on the kintaro, as the 10 has 0.3tons/missile per salvo instead of 0.35tons/missile per salvo.
I would personally run it like so: Same alpha, slightly lowered max dps, better cooling efficiency and faster. Could stick to a light 255 instead and get 2 tonnes of ammo, AMS+ammo etc. With a 255 and Light-Ferro you can get a heatsink and half a tonne of ammo. For MRM's, the 40 and 10 are the 2 best when it comes to weight-efficiency. All others have extra weight per 10 missiles.
Yes, but the MRM40 has a longer cooldown (causing the higher cooling efficiency, lower dps/hps for the weight) and higher spread than the MRM10, and generates ghostheat together so the cooling efficiency is skewed! 2xMRM20 is heavier, but synchronises better in my experience.
