CP-11-A-DC “Psychlops” (UAC20, 2SRM6A, 2SRM4A, 2ML, LFE340)
4/5,
1 rating
Thread in 'CP-11-DC' started by ShiverMeRivets, Mar 6, 2019.
  1. ShiverMeRivets
    214
    49
    The 73(93) alpha monster.
    Decent speed, arm lasers for UAVs, lights and targeting damaged components. UAC20 can jam, so use double tap with consideration - save it for the alpha strike. When it jams you still have 53 damage from the srms and lasers.
    It is a bit hot, so carry a coolshot, mind the heat of the lasers and double tap only when you are still cold. After a double-tapped alpha, you will not need a second double tap anyway...
  2. Lorgot
    Lorgot Advanced Member
    403
    72
    Or
  3. Excalibaard
    5,277
    I've been a big fan of the (U)AC20 cyclops with a bunch of missiles. MRM60 UAC20 is still one of my faves, but I run a similar build on my 11-A with one less SRM4+A and it wrecks, even if it's a bit short ranged and not quite as strong as the 10-Q with only missiles, or the Sleipnir with only ballistics.
