It's ALWAYS a pain in the ass to deal with lights/Mediums when sitting in a LRM Boat. So i tinkered around with the C4 and came up with this. Lights who want to cuddle up with this Kitty will definitely get hurt Alternate Version: (with SRM4 and LRM10+15) Feel free to rate and comment Proximo
I like your first build. The 2nd build uses too many small LRM and SRMs, each costing an extra slot & ton...plus add Double Heat Sinks. I've tweaked your first build for a little more survivability, since it's already so good. Tips: Crit pad! All those LRMs in side torsos, with an XL = Terrifying! Pack the AMS and BAP together, less chance for ammo explosion, or equipment failure. Also, always load LRM in the head, and never SSRM or AMS. The head slot is the first used, so the LRM ammo will never be there, by the time you might fear an ammo explosion. AMS and streaks, however, might last all round. Your arms and RT / LT have the same armor, but the torsos have much more hp...which means more chances for an ammo explosion, which with an XL = insta death. I moved the ammo from the (now equipment empty) LT to the arms, where they are more likely to not explode if targeted. Personal Choices: If a light targets you, you only have <10 dmg to fight with, and that's just way too dangerous. While I love TAG too, you already have artemis. I swapped TAG and a ton of SSRM ammo for another MPLAS, bringing your short range dmg up by 60%!
