Had to. No way you'll live to use all 1500 missiles, so you might as well try to mount some JJs or try to increase your speed a little. But tbh, it had to be done.
5/5, .... There are no words ... EDIT: Hypothetically, this version might actually have some practicality: I probably went overkill with the ammo (though I could probably use all of that in practice) so swap some for heatsinks as needed. better armor, cooling efficiency, and uprated engine should actually make a semi-workable build out of it.
Nice troll build However, if you take it down a notch to MRM90 it could be totally viable. Fire left/right to avoid ghost heat.
