CPLT-K2 Terminator MKII (1x AC20, 1x ERLLas, 3x MLas, STD260)
Thread in 'CPLT-K2' started by Blagg Zear, Aug 15, 2013.
  1. Blagg Zear
    Want Boom.Stick power but dont wanna go slower than Stockspeed? Take this..
    just tested this build.. If you can place well aimed shots with your AC20s combined with your ERLLas, and Alphastrike if your Heat is below 30%, you can do fantastic scores!
    Plenty of Kills and alot of Damage:
    [img width=700 height=437]http://i44.tinypic.com/29d6hv.jpg[/img]
    Blagg
  2. The Verge
    This build is perfect. Good STD engine, a nice shield torso, and plenty of ammo. 5-5 stars.
  3. ArkNemesis
    ArkNemesis Well-Known Member
    107
    I have made a small variation of your design :
    It is really a good and fun build to use, and a cheap one too.
  4. Blagg Zear
    Nice Tweak. But you need to manage your Heat very well with that ERPPC. Why not use a cooler PPC instead? Just an option.
  5. ArkNemesis
    107
    I mainly use ER-PPC to snipe from distance before the "real" fight begins. As it is used alone, heat is easy to handle.
    When it comes to close combat time, I use it only as a "finisher". With this kind of brawler configuration, I have to go really close and I don't always have time to check the distance between my target and me. The ER-PPC having no min range, I can use it without remorse :p But yeah, sometimes, I overheat at the worst time :rolleyes:
  6. Blagg Zear
    Yeah i often come to the overheat limit with the OP.build in heavy brawls especially if its not only 1v1. So with an ERPPC it could be even more difficult. You get high Snipe Range with some Burst Damage but have to sacrifice Close Range DPS. Its a fair trade.
  7. Maxellum
    Maxellum New Member
    Hehehe, nice build !
    My little variant is 1xAC/20, 2xMPLasers, 1xAMS, STD300 ( mooaarr speed :p)
  8. Blagg Zear
    You can also try this if you want more Speed:
    :rolleyes:
