CTF-4X "Boomshakalaka" (2x LBX10, 2x MG, 2x Flamer, XL255)
Thread in 'CTF-4X' started by Zalor, Oct 21, 2013.
  1. Zalor
    Zalor New Member
    Was messing around with my new 4X, and Dr Frankenstein'd this thing up. It's very close-range oriented and I personally love Brawlers. See if you like it.
    CTF-4X
  2. The Verge
    Your Crazy, And I love it! I can only give it 4-5 stars, but you will have sooo much fun brawling with this!
  3. Zalor
    Zalor New Member
    I'm sure I will if I can ever afford the engine. Premium Overlord time, ACTIVATE.
  4. Ilubabe
    Ilubabe New Member
    In my Opinion this built is poor. The LBX won't kill something, you need everytime someone who open up a target. Alone you make no Pinpoint damage to kill your enemy. And the XL255 isn't helpfull too in this direction. This built have to be played in a coward playstyle. And because of the slow movment of the CTF-4X you won't get out of any situation. In the end you may score Kills with this built, but you arn't helping the team at all. - If you wanna do something with flamers and mg's go play a JM or Spider. The CTF4x isn't usfull with such a spread loadout.
  5. epikt
    Well, this build sure isn't competitive. But it looks fun.
    PS: hadn't look closely, it's actually badly built. Two thoughts:
    - you don't need that many DHS. In fact the 10 DHS included in the engine are already too much (100% cooling efficiency mean you can fire nonstop at max rate and still be heat neutral)(usually, try to be between 30% and 50%)
    - CASE are useless with XL engines, it won't prevent from your side torso being destroyed, and thus your engine, only for the damage to spread on center torso.
    Here is a suggestion (with standard engine and AMS):
  6. Zalor
    Zalor New Member
    Thanks, I am definitely lacking in experience as far as these types of mechs are concerned.
    One day when I can afford it I will give this one a try.
