Deadly long range sniper. 30 Rnds per Gauss means plenty of pain and since they cause no heat you can spam all day long and not over heat when using Alpha Strikes. Pair this with my macro and you can fire all 3 simultaneously even against moving targets and have a good chance of hitting if you lead properly. Basically fire an AC40 at 700 meters and hit a pin point spot? Yes please...gimme more of that.
I was tweaking Michael's gauss-a-phract and reinvented this build. Mine just load one less ton of ammo, but has AMS: I'm really not the best sniper around here, so I didn't achieved anything spectacular with this build. But I really think in the hand of a skilled sniper it can be really deadly. The low position of the weapons is a problem though, I'll try a similar loadout on a jagermech, to test if it makes it better despite the 5 less tons.
Can be tough to play on hilly maps but if you get some ranged shots ooh boy look out. I use this on my Jager as well, dual gauss 2 MLs and 5 tons of ammo...AMAZING on the jager with its high up slots
