Dragon Slayer "alcholix' Dragon Slayer" (1xGauss, 1xSRM6, 1xSRM4, 3xML, 4xJJ, XL360)
Thread in 'Dragon Slayer' started by alcholix, Jul 3, 2013.
  1. alcholix
    alcholix New Member
    Figured this mechs main thing was mobility, so i tried as hard as i could to manage that whilst still providing some decent firepower.
    This one is same as above, but with one less heatsink and one more ton of Gauss ammo.
    One less heatsink in exchange for an Srm 6 instead of the Srm 4. i feel this is the least effecient version. There is only 10 tubes on the launcher port, so it fires 8 followed by 2 wich is why i originally had the srm4/srm6 combo.
  2. wisprr
    wisprr New Member
    Quick question, can you confirm that the Dragon Slayer actually has 10 missile tubes on her left torso, because Smurfy says there is only 6?
  3. alcholix
    alcholix New Member
  4. haxbagoosh
    haxbagoosh New Member
    Hey man cool build. However I feel like using the XL 360 is a little excessive. I can see the 350 for the 4th heat and the speed, but I think the weight put into the 360 could be put into better use elsewhere. I defintely approve of using a SRM6 + SRM 4 instead of SRM6x2. No point in using more than you have tubes. I kinda like SRM4x2 also. 2 SRM4s combined with the 350 might let you do some more interesting things with that left arm.
