DWF-A Jack Rabbit (3x cERPPC, 3x cERLL, 2x cSRM6)
Thread in 'Dire Wolf Omni Builds' started by FuzzyBunny, Jun 16, 2014.
  1. FuzzyBunny
    FuzzyBunny MechSpecs Addict
    This is my Frankenrabbit wolf. Designed to use every perk possible to increase manueverability of the weapons. You have the twist bonus from the Right Torso, and the arms unlocked from the use of just lasers in the A right arm module.
    You are easily able to poke either arm out of cover to hit things at range. You also pack enough DHS to chain fire which ever arm you prefer to sustain good DPS. Finally if you're feeling froggy enough you can alpha some poor fool into the ground with an obscene amount of alpha damage.
  2. Lokesh
    Lokesh Active Member
    Does having the actuator in just the one arm allow both to move?
  3. FuzzyBunny
    Yes, just like the Highlander and Victors.
