_ 135 damage for less than 45 heat (including ghost heat). Damage is going to spread all over and you are moving at a speed that let's you just barely out pace a glacier. After the opening two salvos, just use arm-mounted MRMs as heat allows. 80 damage for 24.61 heat. Not too much ammo, but 2,280 potential damage. Needs testing if we have some brave or crazy souls. I expect it will perform worse than similar builds with more indirect fire options and back up weapons. http://mechspecs.com/threads/fnr-wr-wall-of-missiles-2xmrm40-2xlrm15-4xmpl-ecm-lfe-300.15980/
Trial run I may have underestimated the killing effectiveness of MRM120 inside of 180 meters. Doubly true for mechs that have been damaged. Try to shoot medium and light legs if you can get a clean shot.
