This has been argued before when I posted the Auto Hotkey scripts/settings for AC macros as well as PPC/AC20 timing macros for mouse clicks etc. PGI never contacted me in regards to the matter and I happen to know two of the individuals who frequent this site complained about them. I wouldn't sweat it. Also, posting GM conversations is a no no.
For me it kind of works, but doesn't always fire the PPC linked to the Gauss, seems there's only a short window of time when they fire both togheter, but if I hold the charge longer and fire when it's about to fade only gauss fires....why ? also there's no GUI nor sounds is this normal now ? (1680*1050) EDIT: ok I realized what happens when only gauss fires, it's when I press F too or when I start charging before the cooldown is gone, any way to fix it?
Yeah, it seems to have a problem when certain other keys or actions are engaged(try holding shift for arm lock for instance; the PPC's just wont fire). Also, the charge window is linked to a sleep timer as the progress bar loads. Depending on how fast your computer is, it might go too fast or too slow; hence your problem linking the PPC's. I have a feeling your CPU is a touch faster than mine. I am working on resolving both of these issues! There's no sounds included; just what's built into MWO. I haven't tried 1680x1050, but I think I may have an old monitor that supports it, so I'll try it out. The GUI should show up when you're in a match, but my pixel checker is probably looking in the wrong place for the "down arrow" on the targeting computer's compass(that's how I check if you're in a match to display the GUI). That's a major caveat of working with multiple resolutions. I'm trying to find a way to remedy this for all resolutions. Basically I either need to recode my pixel checker to do some math with your game's resolution, OR give you a tool that lets you place a box over the described "down arrow" so my program always knows where to look via your user input. Unfortunately I'm new to the AutoHotkey stuff, so there's probably some features I just don't know about that would make this work a lot better. It's a fun project though, and it actually helps me learn for work(AHK can do a ton for you at work), so I'll perfect the script soon. Since the GUI isn't working for you, you may want to look at the original AHK script called "GaussBeeps" until I can get this working for you! It's the same thing, but it uses actual timers(rather than looped sleep timers, so it'll work correctly for you) and beeps instead of a visual overlay. GaussBeeps Code: #NoEnv ; Recommended for performance and compatibility with future AutoHotkey releases. #Warn ; Recommended for catching common errors. SendMode Input ; Recommended for new scripts due to its superior speed and reliability. SetWorkingDir %A_ScriptDir% ; Ensures a consistent starting directory. #singleinstance Force ;Set gauss to right mouse group, ppc to group 6 (6 key). hold right mouse to charge. ;firing window marked with beeps. release right mouse to fire. PPC will only fire in the gauss firing window. ;Additional beep indicates recycle complete. Rbutton:: settimer, gCharge, 750 Charging := 1 return Rbutton up:: settimer, gCharge, off settimer, gWindow, off if ((Charging == 0) and (charged == 1)) { settimer, recycle, 4000 send, {6 down} sleep, 25 send {6 up} } charged := 0 charging := 0 return GCharge: settimer, gCharge, off settimer gWindow, 1250 charged := 1 Charging := 0 soundbeep , 1000, 50 return gWindow: settimer gWindow, off charged := 0 soundbeep , 1000, 50 soundbeep , 500, 150 return recycle: settimer, recycle, off soundbeep, 2000, 100 return
I spent a couple hours rewriting portions of the script for timing. I've also tweaked it for 1680x1050. I think you'll find it acceptable now. Let me know if you continue to have trouble, and keep watching here for further updates.
with this version I see the graphical part when launching the patcher but not ingame and it doesn't shot togheter the PPCs with the gauss so I'm still using the first one you posted even if it has some bugs it still makes the gauss viable so thanks if you can fix it, if not still great help for me !
Been meaning to write one of these for a long time, but I've been lazy. One of the things I started on but never finished was adjusting for the projectile speed difference between PPCs and Gauss via page up/page down and visual feedback via overlay (100/200/300m) I think the math was something like 3ms of delay to hold back the Gauss for every 20m of travel on the PPCs.
Doh! There must be an issue with a color difference between our monitors(or something I'm missing right now). I'm going to have to build a tool that lets you select the color and the location of that compass down arrow. Speaking of; the Clan HUD is a different color, meaning you'll need to be able to select two different colors. I'm really puzzled why the PPC's aren't releasing for you. I'll see if I can find any issue. This is a stupid question, but your PPC's were in group 6 right? I'm sorry to say I don't intend on putting any more work in on this project this weekend. However, I'll be back on it next week. [quote author=SniperCzar link=topic=6829.msg45120#msg45120 date=1402770424] Been meaning to write one of these for a long time, but I've been lazy. One of the things I started on but never finished was adjusting for the projectile speed difference between PPCs and Gauss via page up/page down and visual feedback via overlay (100/200/300m) I think the math was something like 3ms of delay to hold back the Gauss for every 20m of travel on the PPCs. [/quote] Nice! You're welcome to improve on the project if you're interested. Obviously you'd be listed in the credits for your work. Even if you just want to work on the fun bits like that. If not, that's good information to know if I ever decide to advance the script to that point, so thanks! FYI, if you do decide to add this to the script, it'll go somewhere under the 'Rbutton up' section. I'm guessing you'd call a 3ms increment timer based on target distance. Reading the distance off the screen could be rather difficult, but I'm not sure; I've never tried it: Code: Rbutton up:: settimer, gWindow, off if ((Charging == 0) and (charged == 1)) { send, {6 down} sleep, 25 send {6 up} Recycling := 1 settimer, gRecycle, 185 MyIndex3 := 0 GuiControl, +CFACC2E, MyProgress3 GuiControl,, MyProgress3, %MyIndex3% } charged := 0 charging := 0 MyIndex1 := 0 MyIndex2 := 100 GuiControl,, MyProgress1, %MyIndex1% GuiControl,, MyProgress2, %MyIndex2% Return
Yes, I put them in Group 6 infact with the other version they work for me, (always unless I press F or start recharging before the cooldown is over). No problem, the the most important part works with the v2
Okay, I have an updated version for you guys to try. This one takes a different approach to turning the overlay on and off. It's not as cool as being automatic, but it should work for just about anyone. When you get into a match the GUI will not attempt to launch itself anymore. You'll need to press Ctrl+Alt+G(While in-game) to toggle it on and off. If you forget to toggle it off when you exit MWO the Ctrl+Alt+G combo will not be able to hide the overlay(an AutoHotkey limitation it seems). You'll either need to exit from the tray icon or use the key combo Windows+Alt+G. As always, let me know what problems you have. At this time, I'm not able to explain why several of you are experiencing a problem with the PPC group not firing. I'm continuing to investigate the problem. Please let me know if there's any change with this version. Code: /* BEGIN COMMENTS CREDIT: kuangmk11 posted a wonderful AutoHotkey macro at this link: http://mwomercs.com/forums/topic/134382-cant-you-just-macro-the-gauss/page__view__findpost__p__2751940 His macro was utilized as a base to build a Gauss overlay for MWO. ProtoformX is the primary contributor to this project. INSTRUCTIONS: 1.) Place the Gauss rifle in Weapon Group 2(Must be right mouse button). 2.) Place the PPC's or other weapons you want to fire with the Gauss rifle in Weapon Group 6. 3.) Launch the script and run MWO. It doesn't matter which order you start them in. 4.) while MWO is active, press Ctrl+Alt+G to toggle on and off the overlay. If MWO is not active, instead press Windows+Alt+G to toggle. Hold the right mouse button to charge the Gauss and use it just like normal. On release, Weapon Group 6 will also fire. Weapon fire sync will work whether the overlay is active or not. PROGRESS BAR LEGEND: Lime: Weapons reloading status. Blue: Gauss charge remaining. Yellow: Charge status. END COMMENTS */ #NoEnv ; Recommended for performance and compatibility with future AutoHotkey releases. #Warn ; Recommended for catching common errors. SendMode Input ; Recommended for new scripts due to its superior speed and reliability. SetWorkingDir %A_ScriptDir%/B ; Ensures a consistent starting directory. #singleinstance Force xMidScrn := A_ScreenWidth //2 yMidScrn := A_ScreenHeight //2 Gui1X := xMidScrn - xMidScrn *.1 Gui1Y := yMidScrn - yMidScrn *.15 Gui2X := xMidScrn Gui2Y := yMidScrn Charging := 0 MyIndex1 := 0 MyIndex2 := 100 MyIndex3 := 100 Toggle := 0 Recycling := 0 Charging := 0 Charged := 0 percent := 0 Gui, Destroy Gui, +AlwaysOnTop Gui, Color, Black Gui -Caption Gui +ToolWindow Gui, Add, Progress, vMyProgress1 h8 w130 cFACC2E Background2E2E2E xp+20 yp+130 Gui, Add, Progress, vMyProgress2 h8 w130 c2E9AFE Background2E2E2E yp-8 Gui, Add, Progress, Vertical vMyProgress3 h49 w8 cLime Background2E2E2E xp-22 yp-58 Gui, Show, Y%Gui1y% X%Gui1X%, MWO_Gauss_Overlay, NoActivate, Title of Window WinSet, Transcolor, Black, ahk_class AutoHotkeyGUI GuiControl,, MyProgress2, %MyIndex2% GuiControl,, MyProgress3, %MyIndex3% Gui, Hide WinActivate MechWarrior Online Return ;When in Windows press Windows+Alt+G to toggle the script on and off #!G:: toggle:=!toggle ;toggles up and down states. if toggle { Gui, Show WinActivate MechWarrior Online } Else { Gui, Hide } return #IfWinActive MechWarrior Online ;When in MWO press Ctrl+Alt+G to toggle the script on and off ^!G:: toggle:=!toggle ;toggles up and down states. if toggle { Gui, Show WinActivate MechWarrior Online } Else { Gui, Hide } return Rbutton:: IF (Recycling == 0) { Charging := 1 Loop,1 { Settimer, gCharge, 75 } } Return Rbutton up:: settimer, gWindow, off if ((Charging == 0) and (charged == 1)) { send, {6 down} sleep, 25 send {6 up} Recycling := 1 settimer, gRecycle, 185 MyIndex3 := 0 GuiControl, +CFACC2E, MyProgress3 GuiControl,, MyProgress3, %MyIndex3% } charged := 0 charging := 0 MyIndex1 := 0 MyIndex2 := 100 GuiControl,, MyProgress1, %MyIndex1% GuiControl,, MyProgress2, %MyIndex2% Return gCharge: Loop,1 { GetKeyState, state, Rbutton, P if state = U break MyIndex1 := MyIndex1 + 11.12 GuiControl,, MyProgress1, %MyIndex1% } if MyIndex1 >= 100 { settimer,gCharge,off Charging := 0 Charged := 1 GuiControl, +CRed, MyProgress1 ;RED GuiControl, +CRed, MyProgress3 ;RED GuiControl,, MyProgress1, %MyIndex1% GuiControl,, MyProgress2, %MyIndex2% GuiControl,, MyProgress3, %MyIndex3% settimer, gWindow, 125 } Return gWindow: Loop,1 { GetKeyState, state, Rbutton, P if state = U break MyIndex2 := MyIndex2 - 11.12 GuiControl,, MyProgress2, %MyIndex2% } if MyIndex2 = 100 { settimer, gRecycle, off GuiControl, +CLime, MyProgress3 GuiControl,, MyProgress3, %MyIndex3% Recycling := 0 } Return
much better now, I can keep F pressed or other buttons, only time it doesn't fire the ppc is when I start charging before cooldown is gone. guess what ? I used this to my advantage and got used to it, and when I'm overheating I can fire only the gauss like that GUI still doesn't work, pressing this combo sends me to desktop. EDIT : running the game in full window instead of full screen, the GUI works as well. I also found out that when loading only the gauss because of the cooldown overlay, the bar doesn't turn red, even more helpful I think I like it this way now Great job and thanks !
Woohoo! I can't tell you how happy I am to see someone else finally having the chance to enjoy this thing. Changing your MWO setting to Full Window is definitely a requirement for this overlay; nice catch. I should add that to the OP. I'm thinking I might be able to restrict input from the right mouse button until the cool-down timer completes. This way you can hold down the button before the cool-down completes and the script will still activate the PPC's. That's how the hamster on the wheel in my head says it works, anyway. :unsure: So here's what's coming down the pipeline: *Fix bug where the script doesn't engage when clicking to charge the Gauss rifle before the weapon cool-down is completed. *Full GUI interface to configure the overlay location, size, colors, and hotkeys. Kinda like Fire Control. *POSSIBLY de-synchronization of the Gauss and PPC trigger pull timing based on the distance of the target. This is going to depend on some kind of OCR software to read the target distance of the HUD. I have a feeling this is going to be tough to process quickly. We'll need to pole the distance something like 10 times a second to make it worthwhile; maybe more.
I was just thinking numpad entry or add/subtract range increments, displayed back to the user through an overlay HUD, but reading the HUD would be pretty awesome, too.
wow, this is a blast to use, but surely on the edge of the eula, would be nice to have them confirm if its allowed or not thank you protoformx
Hi ProtoformX, nice work! Hope I could use it. The versions hosted here do not activate when i press ctrl-alt-g. Autohotkey is runnig. Saying: Script lines most recently executed (oldest first). Press [F5] to refresh. The seconds elapsed between a line and the one after it is in parentheses to the right (if not 0). The bottommost line's elapsed time is the number of seconds since it executed. ---- C:\Users\Oliver\Desktop\GaussOverlay.ahk 040: SendMode,Input 041: SetWorkingDir,%A_ScriptDir%/B 045: xMidScrn := A_ScreenWidth //2 046: yMidScrn := A_ScreenHeight //2 047: Gui1X := xMidScrn - xMidScrn *.1 048: Gui1Y := yMidScrn - yMidScrn *.15 049: Gui2X := xMidScrn 050: Gui2Y := yMidScrn 051: Charging := 0 052: MyIndex1 := 0 053: MyIndex2 := 100 054: MyIndex3 := 100 055: Toggle := 0 056: Recycling := 0 057: Charging := 0 058: Charged := 0 059: percent := 0 062: Gui,Destroy 063: Gui,+AlwaysOnTop 064: Gui,Color,Black 065: Gui,-Caption 066: Gui,+ToolWindow 067: Gui,Add,Progress,vMyProgress1 h8 w130 cFACC2E Background2E2E2E xp+20 yp+130 068: Gui,Add,Progress,vMyProgress2 h8 w130 c2E9AFE Background2E2E2E yp-8 069: Gui,Add,Progress,Vertical vMyProgress3 h49 w8 cLime Background2E2E2E xp-22 yp-58 070: Gui,Show,Y%Gui1y% X%Gui1X%,MWO_Gauss_Overlay,NoActivate, Title of Window 071: WinSet,Transcolor,Black,ahk_class AutoHotkeyGUI 072: GuiControl,,MyProgress2,%MyIndex2% 073: GuiControl,,MyProgress3,%MyIndex3% 074: Gui,Hide 075: Return (15.33) Press [F5] to refresh. Is the GUI-Version out yet? Greetings!
I disagree. The info it shows up is the same u have in the lower right weapon bar, also the macro itself doesnt aim for you, it just shows u the info and sincronice weapons firing linked. And for the scripter: Im not planning to use the mod, but i do appreciate the effort placed in it. Thanks for expanding the comunity
honestly I find no advantage with this and thus no problem. All the information you need is actually right there by your cross-hairs already. I personally have no issues timing a Gauss+PPC without aid. Previously I've setup a macro for LMB and RMB where you charge using the RMB, then click the LMB to fire PPC and release gauss. I timed the gauss release just right so that it hit at the exact same time as the PPC @ 600m. Then another macro bound to a button near the LMB that was timed for 400m. Trying to maximize pin-point and all. In the end, I didn't like changing my mouse profiles for specific builds and just time it all myself without aid. A macro might be a crutch for other players though, making the meta even more dangerous on the battlefield in general, which can be pretty annoying at times.
