GHR-MJ “Grasswalker” (LB10X, 6MPL, 1ERSL, XL340)
Thread in 'Mjölnir' started by ShiverMeRivets, May 15, 2019.
  1. ShiverMeRivets
    214
    49
    Maximum brawl with the fastest crawl!
    Yes, it is a grasshopper with no jump jets - No available crit slots. Instead, we cram in it the biggest engine it can take, that will propel it to around 85 kph after some speed tweek nodes. For a mech taller than an Atlas with assult level armor (great armor quirks!) this is hilarious.
    I refrained from using XL on this mech for a long time till I realized my mistake. It is very tanky, gets ST armor quirks (unlike other GHRs) and the ST hitboxes are small. You very rarely die to a ST loss without being opened and red everywhere else anyway.
    Cooling looks decent, but the numbers lie. You will run hot, so spec for maximum cooling and carry coolshots.
    If you must have JJs, give up the arm lasers, and go with 5 MPLs in the torso, drop a DHS and get 3JJ (3 allows you to jump onto the center platform in factory map for example). You can scrape 1 free ton to use for 2 SLs or whatever.
    This is a different beast, so I will not post it here.
