Golden Boy "Golden Turd" (1x LRM20, 4x SSRM2, 2x MLas, TAG, BAP, XL255)
Thread in 'Golden Boy' started by enileph, Sep 30, 2013.
  1. enileph
    Well.
    I guess this is something only Golden Boy can pull off, that having said, the other Kintaro variants are way better.
  2. Leonhart
    Leonhart Advanced Member
    499
    4 stars for the name. says it all.
  3. Aylek
    This isn't as bad as you're want it to look like. I took your build for a starting point since I liked the flexibility it grants. Depending on your playstile you probably can get away with 2 tons of SSRM ammo. Those 3 tons of LRM ammo are telling me that you're not storming into the middle of the fight anyway. ;-)
    Long story short, I made some adjustments to your build, and voÃla... It's pretty good.
  4. Josef_Koba
    Josef_Koba New Member
    I'm loving this thing. I was trying to figure out a good build for the GB, given that it's a lot slower than its sisters. Turns out the LRM with Artemis and TAG work very well in combination with the SSRMs and BAP. The very first match I did 400 damage with two kills. It has plenty of ammo for both systems, and I suspect that she'll shine once I get more experience driving this chassis.
  5. greenbeard
    greenbeard Active Member
    95
    Good times.
    for me this excels as an outside support unit and D-DC guard; as long as I don't run off like Ronnie Dobbs things go smoothly. I tend to stay out of reach until the ammo dips low. I chainfire the SSRM's vs non AMS mechs to save ammo. I usually hold the 400-500 damage line with this build. Either way, it makes a good wad of cash and is fun to play.
    ...that 1k damage by my lancemate didn't hurt either
  6. Todo Ringman
    Todo Ringman Junior Member
    39
    Well I think that putting instead a STD275,adding 1streak,removing the lrm20, and putting 3mls instead of a tag is better.
  7. Aylek
    Wow, downvoting this one clearly means no real testing has been done before. Such a great build. :(
  8. enileph
    Due to the change of battlefields I do suggest running with a bit more LRM ammo, you can take some from the streaks ammo patch.
