Missiles are cool right? I certainly think so. This build takes advantage of all four missiles slots on the GRF-3M, allowing you to support your team from afar while at the same time lets you prevent those pesky lights from chewing on your juicy ass. Use of the LRM 20 allows you to fire a massive salvo, of which the 3M has enough launcher tubes for, maximizing the amount of missiles that you can put out without having to remove one of your other streak launchers. Trust me, three heads are better than two, I mean, just ask Dodrio. With 83% cooling efficiency, you'll pretty much never be overheating. There's enough ammo for 36 left clicks on the LRM 20 and enough ammo for 33.3 left clicks on the Streaks. Original Build: http://mwo.smurfy-net.de/mechlab#i=128&l=43944a6007437fb0c7f8457ea41ee2199c331ca4 With TAG: http://mwo.smurfy-net.de/mechlab#i=128&l=fd47e0c5cad6e73eadd80fd15e9f7913fce6ea8f
That being said: you have more than 14 free slots => upgrade to endo-steel! You gain 2.5t from it, do what you want with it. I suggest Artemis upgrade and one more ton of streaks ammo. Also, you don't need so many DHS => XL300 and a MLas http://mwo.smurfy-net.de/mechlab#i=128&l=6cac956e57abaf32b264f2af526ea656766412ee
