My go-to! 4x cERMLs on your four high mounts for good ranged peeking, 4x cMPLs on your belt for close-range punch and crit! Throw in a TC1 for those delicious bonuses and you're set for a strong mid-ranged skirmisher. Add two jump jets and the max engine and watch that agility bump up to the craftiest Hunchie you've ever seen! Enough DHS to keep you manageable, plus two in the legs for extra cooling in water, max armor, and shield arms. You will incur ghost heat when alphaing, so use two groups for range vs brawling and you'll be set for easy heat management. I run with cERML Range Module and cMPL Cooldown Module. This makes your ERML comparable to IS LLas (same damage, close range) and MPLs strike fast enough to strike fear into even most assault pilots. I've found this to be the best balanced build for the HBK-A. Give her a shot, I promise you'll be happy with the versatility and balance. Cheers.
