HBR-F "Elster" (2LPL+6ErSL+ECM)
Thread in 'Hellbringer Omni Builds' started by Ilubabe, Oct 20, 2016.
  1. Ilubabe
    Ilubabe New Member
    Even Mordor can't resist. I was bored of the LPL+ErML combos. Main reason I looked for a new build is the problem of lesser rang you can not defend yourself without generating to much heat. Also at dream range around 660m (maximum rang of C-LPL) ErML do not do that much punch anymore.
    The build is from the attributes best suited for poking out of fog - ideal around the corners. And if the situation needs it; you may have enough armor left to punch through the rest of structures in closer combat under 200m.
    Link to the setup:
    If you think you may need more armor on the legs, you either shave some of the right arm and distribute it or play with one less DHS. Also a TC I may be interessting to assist the Lasers.
    Modules:
    • C-LPL Range
    • C-ErSL Range
    • Advanced Seismic
    • Later: Radar Deprivation or Target Info Gathering
    Consumables:
    • At least a cool shot 9/9
    • Arty/Airstrike or another coolant is good for the second slot
    This was the second ride I have done with the "Elster". Since it was on the revamped Terra Therma map, which is the hottest of all, she did for a full Laser build surprisingly well and for a mech with no pilot quirks.
    Here is a better clip for the Elster (third match after injection) with a TC1 instead of one DHS (skillpoints in the two pilot skils for heat are set no 2x bonus at this time):
    This clip is of the second match, I did with the Elster, which was actually recorded before the above and done with zero skills in it:
    * Games were played in Tier 1
    invernomuto likes this.
