HBR-F "Nein" (2x HLLas, 6x cERML, cECM)
Thread in 'Hellbringer Omni Builds' started by Ragnahawk, Jul 25, 2017.
  1. Ragnahawk
    Ragnahawk Well-Known Member
    219
  2. Excalibaard
    Ok.
    I'm going to shoot your legs if I see you on the battlefield ;)
    Killed the RA, used the tonnage of the ML for a TC1 (4% beam range for 1 ton, yespls), and the armor for the other components. Moved the HLL higher up for the range advantage they have. May cut 1 DHS for a little additional armor.
  3. Ragnahawk
    219
    and while your chasing my legs which are concealed by a high point, I will crit your armor in one and 1/8 ounces of laser vomit. :hungry:
  4. Emptied an arm and moved 2x HLL to one side so you still have at least a 42 point alpha left after loosing a ST.
    Shield with the right side to protect ECM and keep 6x ERML and 22 heat sinks.
