Casual HBR-Prime "Kuroi GUN" (2xcUAC10, 3xcERuL, cECM) SET
Thread in 'Hellbringer Omni Builds' started by krevLL, Nov 1, 2020.
  1. krevLL
    krevLL Insane Fire Troll
    396
    126
    153
    Let's change things up! We all know a Hellbringer is good at ATMs, and great at lasers. But it's harder to build a decent ballistic HBR given the lack of Endo or even Ferro (Stupid chintzy clan designers...).
    So with that in mind, and knowing that running dual UAC10's is a fairly safe recipe for a clan heavy, this is what we ended up with:
    It's not an astounding amount of ammo, but for QP it's usually sufficient, and the micro lasers are there strictly for if you run out of ammo or have the bad luck of losing the right torso early.
    It's still a fragile clan heavy mech so you need to use the speed and ECM to stick with a group and generally get ignored while you blast away with the autocannons. Jam duration and magazine skills in addition to the standard Hellbringer ECM skills are the only recommendations I have, rest is up to you.
