Heavy Metal Ronpower HM (1x LBX10, 3x MLas, 1x LRM20, 1x LRM10, 2x JJ, STD300)
Thread in 'Heavy Metal' started by ronaldson, Sep 3, 2013.
  1. ronaldson
    ronaldson New Member
  2. ronaldson
    Little new to this site. Trying to upload my mech as I've been doing pretty good in it and figured I'd get some feedback. I use all the tubes I can to fire my LRMS in one volley, then when it's time to get up close I use the lbx 10 and the three mid lasers. I find the lbx's spread is pretty reasonable even at a mid range.
  3. Leonhart
    Leonhart Advanced Member
    499
    Welcome to the site!
    First and foremost you are going to need to follow this format if you are ever going to get most people to look at it:
    http://www.mechspecs.com/forum/index.php?topic=1744.0
    We need to be able to see your mech.
    Then you need to fix this issue or the mech post will be deleted.
    http://www.mechspecs.com/forum/index.php?topic=2279.0
    After that we'll be happy to look at it and help out ;)
  4. ronaldson
    Hey thanks. Yeah I didn't know how to post it the correct way, but I will make sure I do it right from now on.
    Also Whoever edited my post to make it legible. Much appreciated.
  5. The Verge
    I saw this build the other day, and was not afraid of it. If it was an AC10, I think this would suit this build better.
  6. Blagg Zear
    Zero Rear Armor?? You sure about that? I would drop one JJ and try to add TAG (and BAP) and more Ammo
  7. ronaldson
    Ha, yeah my actual build has rear armor. Chock that up to my inexperience on this site. I would have liked an ac20 as well, but the heavy metal doesn't have the slots for it. Used to use the gause, ppc combo, but after the patch wanted to switch it up. Kind of wanted to switch it up anyways. Was almost too successful.
  8. Blagg Zear
    I somehow meant something like this:
    With that LLas you have more ranged Direct Firepower to preserve LRMs, with Tag you can targetlock ECM.Enemies.. and well you have more Shotgun.Bullets. 720 missiles should be enough, and dont know how you can fire 30 Missiles in one blow. However, nowadays its trendy to fire in chain instead of high Alpha.Blows. So dual LRM15s should also do fine. Since the JJs on Highlanders consume 2 tons instead of 1, i recommend to use only 1 JJ, unless you play Jumpsniper. Better use the Tonnage for something else.
