So i reworked this a bit for ya, it doesnt have as much of a direct fire alpha strike, but its a lot more heat efficient, plus you get more armor and missiles out of it. you also get the benefits of your own tag so you can lock those pesky ECM boats. While you lose a bit of your max DPS, you game more sustained DPS. Also i lost the AMS because as a LURMER your going to be standing behind most of your buddies who will be taking missles before you and therefore will have their AMS screen infront of you. Even if you dont one AMS even with the modules wont do much of a difference if you get caught in the open. Oh and i forgot... you get ARTEMIS....
Heat efficient is not a problem since you don't fire LRM and ML at the same time usually. If you are a LRMer you better be armed like one. This way you have ERLL on some direct laser fire. The Battlemaster have great hardpoint for torso energy weapon, it is a shame to waste them. This would allow for some snipery action, and good mid range self defense. Also helps against a ECM heavy target. the 2x ML is for self defence, also part of the weaponary in case your LRM runs out, or when you are in close/confined range. No worry about the heat since you won't be LRMing when you use these. I have included AMS, and that helps contribute to the AMS umbrella of other second line supporter (I do not stand way on the back). If you don't like AMS you can swap that ton and a half for some extra LRM (if you like spamming) or extra Tag/ML. I would say a Tag might be nice, though in this build it is not that important. If you can see something clearly you can ERLL them. Should I make this it's own build?
