I've been working on this one of late and this is the build I've come up with. It is no secret if you really want to load up on the large energy weapons, which is what the 733P is for, your going to be hot. This limits just how often you can actually use these wonderful weapons. So the plan was find the biggest energy weapon I can fire with the most sustained amount of damage, and make it fast for a Highlander to pull out when needed. The theory was to remove everything that didn't directly improve the ability to fire consistently. All the secondary weapons, gone. Who needs ammo explosions anyways? 325 engine even allows me to put another DHS inside of it as well. This gives you an added benefit. The entire left side of your gigantic blue spitting laser of death machine is essentially a shield. You'll lose some DHS, sure, but you won't die and will still be able to fire. The down side is if you lose the right torso you'll be crying bitter sweet tears. So... Say it with me... Rotate to the left to shield. Groupings are: 1) Arm LLs, easily set to go chain fire if needed. 2) Torso LLs 3) One Torso LL This allows me to chain the group with out having to actually chain the group. Chain the arm twice, hit the 3, then hit the 2. I use a mouse so all three are right there.
Have you ever been sniped by Soy? because I have. I've run this build to try it out, many times and it is terrible. You lose ONE section, and ALL your FP is GONE. run an XL, run ERLL, and keep out of the fight. best advice, for a Laser build with A+ overshite that is Fuzzy
Ha! Well I guess I can't please them all all of the time. And yes, I have run across Soy, he's a good shot for sure.
