ultimate brawler nimble than an atlas STD for survivability XL Version with more heatsink and full armor with extra weight left
Could also do standard SRM4s with twin mplas, but your setup probably results in easier weapon grouping.
definately with easier weapon groupings, with thus perks in heat you can just 1 2 1 2 and punch your way throught and in order to mix well rhythmically with the uac 20, yer can put in the srm4 with STD 325 with non Ar srms4
While I won't use regular XL on HGN, cXL seems ok to me. Here is my take. Adding two tiny little laser for longer range. Remove one JJ for a TC1 and cAP.
Easiest fix for leftover tonnage in the XL: Probably not the best, but keeps the efficiency and sustained DPS a bit high More ammo variant:
Don't clan srms spread more? That and someone doesnt seem to realize.... An atlas is worth 1000 damage.
