IIC Build Ideas?
Thread in 'MechWarrior Online' started by enileph, Dec 13, 2015.
  1. enileph
    IIC Build Ideas?
    Yes. Time to think about it.
    JR7-IIC
    Vanilla: probably 6x SRM4!!!!!
    -2: Piece of fucking shit unless good Quirks, use -3.
    -3: ERML/SPL + 2x SRM4
    A:6x SPL, though I guess ERML is ok.
    HBK-IIC
    C: does 4x AC2 fit? If not then 3x then.
    A: Pulse Laser 4 life.
    B: is thinking of 4x SRM6+A.
    C-C: 2x big guns, most likely end up LBX10 though.
    ON1-IIC
    Vanilla: not sure
    A: 4x SRM4, LBX.
    B: not sure
    C: 2x LBX10. That or 2x AC5/LBX5 + 3x SRM4
    HGN-IIC
    C: not sure
    A: SRM + LPL
    B: SRM + ERLL + AC10
    C-C: 2x AC5 + ERLL or LPL
  2. The Verge
    Jenner IIC-2 isn't garbage, it's the same old 4x Medium laser, SRM4 loadout, because stock is terrible.
    Orion C and C-B, mini atlas setups. Either Gauss or AC20's, LRM's in the torso's, and ERML in the arms. Possibly a pure ERLL setup on the C-B
    Highlander IIC, ye-olde 1x Gauss, 3x ERLL. it's the ultimate Assault Centurion.
  3. enileph
    Use Jenner IIC-3 then, you can do the same thng, or have better SRM setup, like 2xSRM2 intead of SRM4. Basically no quirk difference but less hardpoints.
    May try the LRM + Gauss and see how it is.
    Sounds good with highlander IIC, now maybe AC20 is better after the gauss nerf, maybe.
  4. The Verge
    Your not wrong on the Jenner front. Still, since it uses Clan weapons, you might be able to stick a cAP and a c Streak 6 in it.
  5. Nakhar
    Nakhar Active Member
    Both builds are for CW with team drops as you are going to be second line support mech, but if this works my Cheetah and Ebon jag will get swapped instantaneously for both variants , but for now i have to wait for the c-bill release.
  6. enileph
    Blew most of my cbills to dress up the new tos. Tried the Hunchies, and they are good.
    It is rare you get to run around with 4x AC2 in a medium. :)
    PS: Smurfy is currently a bit buggy, not being able to change FF/Endo on IIC mechs.
