Meme KDK-1 "158" (2xcATM12, 2xcHLL, 1xcGauss, 6xcERML, cLTAG, cXL365, Endo, DHS)
Thread in 'KDK-1' started by krevLL, Jan 25, 2020.
  1. krevLL
    krevLL Insane Fire Troll
    396
    126
    153
    Go give the nice teddy a hug... Go on, you'll be perfectly fine.
    Try to get into the sweet spot for the ATMs before unleashing your Care Bear Death Beam at things, for the full 158 damage effect.
  2. Is there a bigger MEME tag that could be used?
    More manageable. (Read that as "less immediate internal damage".)
    Sadly, the 90 tonners probably pull of this kind of ATM24 big punch much better.
  3. CarloArmato
    At the moment I can't verify how much you will overheat with this one, but by downgrading to a slower XL350 and dropping endosteel in favor of more DHS, it should be able to cool down faster...
    P.S.: I can confirm it (on paper). 92% alpha heat pre-skills, 45% cooling efficiency.
  4. krevLL
    396
    126
    153
    Yes, because the original build causes much internal self harm when you alpha. Seems to end badly if you try to be useful with this build!
    Dagonus likes this.
