KDK-3 "Dakka Bear" (4xcLBX10, cXL400)
5 ratings
Thread in 'KDK-3' started by P, May 19, 2016.
  1. P
    P Well-Known Member
    • Dakka Bear
    • C-LB10-X AC 4
    huehuehuehuehuehe
  2. Tank the Frank
    Tank the Frank Benefactor
    100
    Deadly build! I use a XL 380 for moar ammo.
  3. Munky101
    Munky101 New Member
    This build was inspired by Snuggles Time when the patch was released that killed the 4 x UAC-10 build. He suggested the shotgun build and it works quite well, so big shout out to Snuggles. I kept the 400XL as I am a tight arse and couldn't be bothered spending money on another engine
  4. HctPeace69
    HctPeace69 Well-Known Member
    204
    44
    SO MUCH FUN
  5. Munky101
    Munky101 New Member
    still hilarious.....[​IMG]
  6. Flokoloko
    I love this build, even after skills and new tech
  7. 0.8 kph for 2x ERML.
  8. Regina Redshift
    1,293
    Makes me wonder how much a mech crowbar weighs.
    It's also a whole bunch of cbills for a marginal increase in firepower and weapons that are liable to be blow off before running out of ammo.
  9. C-bills are no obstacle for min-maxing...
    Since KDK-3 is still less mobile, torsos will take most of the damage and you will usually have at least one arm left.
    This build has free heat to use. I can easily get four alphas in a game without heat problems. Easy extra 50 damage. I will trade 50 to 100 damage per game for a slight speed decrease.
    Plus the arms offer the only defense against mechs hugging you. Hell you can’t hit a Catapult if it is hugging you.
    Regina Redshift likes this.
  10. Excalibaard
    5,051
    1,107
    Just like the LBX, this has almost no ghostheat to speak of, but I figure it's more focused from a slightly longer range than 4LBX10.
  11. Vick Dalentine
    Vick Dalentine New Member
    I was going to write off the KDK 3 because I HATED the stock build, but this... this build is love. This build is life. I was laughing out loud the first time I took it out and racked up kill after kill after kill. Thank you for saving the Kodiak for me.
  12. Dagonus
    453
    What about mix'n'match?
    Best of both or functionally getting neither?
    I figure you can get the 2 AC10s going at longer range (hence the extra ton of ammo) but once you get in close, you can just use all 4 and still enjoy the crits from 2 LBX10s.
  13. Lorgot
    Lorgot Advanced Member
    403
    72
  14. Redshift Darkstar
    Redshift Darkstar New Member
    love this over my standard 2xuac10 2xuac5 bear build
  15. ShooterMcGavin80
    519
    Even though the Kodiak isn't meta anymore and the Sleipnir and Fafnir can arguable run it better, this is still a very solid and fun build. The Kodiak does have higher mounts than the IS equivalents.
    Skill tree:
    https://kitlaan.gitlab.io/mwoskill/...fe2111cff7f000058080100000080820100#s=Weapons
    2xUAC10 2xLB10X, or 2xUAC10 2xUAC5 are also solid. 4xLB10X has the most reliable DPS, but doesn't have the same midrange presence.
