KFX-D "Light Shower" (2xcLRM5, 2xcLRM10, cAP)
Thread in 'Kit Fox Omni Builds' started by Madwizz, Aug 13, 2014.
  1. Madwizz
    Madwizz New Member
    Silly easy to use and fun light LRM support build.
    I recommend binding all the weapons in each arm as a weapons group. Having low swung weapons it is easy to hit the terrain in front of you when moving over uneven ground.
    Fire just a LRM5 and a LRM10 for sustained damage as this will not lead to you overheating even on Terra Therma.
    Clan LRMs don't have a minimum range like the IS LRMs do. If you do find your self less then 200 from you target be sure to lead your shots even if you have a weapon lock on them or your missiles will miss regardless. But I don't recommend getting that close... ever.
    Here is a screenshot of my best match so far:
  2. Auriga
    Auriga MechSpecs Addict
    599
    I think i would make this tradeoff: 10 missile tubes, and the cAP, for ECM, a cMLas for defense, and more ammo
