KGC-000 "Boxer Crab" (1x AC20, 2x UAC5, 2x ML, STD325)
3 ratings
Thread in 'KGC-000' started by Fherot, Dec 19, 2014.
  1. Fherot
    Fherot Benefactor
    459
    86
    47
    Torn between 4x UAC5 Dakka and AC20 brawler for quirks.
    Solved. All-range left hook, close range uppercut.
    Plenty of ammo, good speed with STD, it kills. Fast.
    Still plenty of ammo left for more boxing.
  2. Sleek34
    Sleek34 New Member
    Used this build, definitely great even against dire wolves!
    I do run it with a slightly different ammo balance between the two ballistics though.
  3. Sir Tiddles
    Sir Tiddles Active Member
    96
    Very effective build. I tried this for a few matches and it never did me wrong. Good job!
  4. Aylek
    I like it and will probably give it a go this evening. As this variant already got amazing AC20 quirks I'd guess you go for UAC5 modules? I can also imagine a mixture like AC20 range or cooldown + UAC5 cooldown.
  5. Aylek
    Pushed this a bit more. Agility is there because of the quirks, and the speed difference when going STD 310/300 is barely noticeable.
    Fherot likes this.
  6. Aylek
    See previous post.
  7. Jack Red
    Jack Red Active Member
    53
    Great build.
    I run mine with XL350, AC20,2xUAC5 and one SRM4.
    Second round with it I had 845 damage and 6 kills.
  8. Jack Red
    53
    Just got a 1000+ dmg with this build.
    Still don't know how to attach the screenshot I took though.
  9. Jack Red
    53
    Whoooohaaaa!
    AC20 + 2xUAC5, XL350 engine.
    Both AC20 modules.
  10. Aylek
    I am currently using a variant of this one for CW:
  11. samuraikitsune
    samuraikitsune New Member
    I liked the build but I wanted to stick it on a different KGC. I came up with this and I am starting to like it:
  12. Excalibaard
    I like that 2x LL variant by Aylek, a lot more ranged pressure than usual crab builds due to the high mounts! Might want to move the UAC5s to the LL side to minimize exposure and I've removed a ton of AC20 ammo for more cooling, you'll probably want to stay ranged a bit more with this variant, so less AC20 usage. You could add it to more UAC5 ammo instead as well.
    On the other hand I want to try out this beefed up variant of the OP:
    Aylek likes this.
