Quirks : Additional Armor L/R Arm +17 Ballistic Weapon Velocity 10% Energy Weapon Cooldown 10% Torso Yaw Speed 25% The loadout is just beautiful, asymmetric with all weapons on the same side and very high mounted LPLs, full armor on the other components, big alpha/pinpoint, good speed (consideting 100T, standard engine and the weapon loadout anyway) and even gets armor quirks for the weak arm, so you can shield a bit with it (the yaw speed quirk is so good for shielding on this assault). I went for this chassis because I think the AC velocity quirk is better then the laser duration, given the already short burn time of the LPLs. Fist game, almost 1K : It's quite hot, so coolshots are great for this build, considering that popping one when you are on heat limit, means +106 damage.
5/5, Top build !!! got me in the 1000 club. I rate this 5 star. I had a pair of 000 for ages and decided to build them a friend to level em up and get speed tweak. This is from my 3rd game in this build. The only unlocks I have on the mech are heat containment and cool run.
