Funny build. You can fire with the 3 Light PPC at the same time without Gosht Heat. The very hight mounted 3 energy hardpoint is perfect for these weapons. For 9 tonnes you do 15 dammages. In comparaison betwin standard PPC you gain 50% damages for 2 tonnes more, but you need to use 6 critical spaces. In this case, it's a good combination to complet the main weapons : LB5X. I like LB5X for three reasons, the very low heat generation it's perfect. 50% less than a classical AC5. It permit to save heat for use energy weapon like... 3 LPPC for exemple. The second reason is the spread. He is low and you can resonnably use it at long rang. Don't forget the max rang of the LB5X (2100m). It's possible to shoot big target at 1000m and keeping a good amount of power. The last, at the end of the battle, when the external armure are off, the critical chance bonus of LBX destroy components at a amazing rate!!! Especialy when you fire 4 LB5X at same time with a cooldown of 1.5sec. The use of this build is very simple. At the begenning of the battle poke with your 3 light PPC. If the space is safe, or the enemies are at very long range, go out with your 4 LB5X. During the mid game, manage your heat by stopping using PPC. For the late game, crush opponents with a continious fire off LB5X. It's quite heat neutral, don't stop firing and aim the open localisation for quick kill.
