KGC-000B "Rowdy Ranger" (1xUAC20, 2xLGauss, 3xERMLas, 3xRL10, LE325)
Thread in 'KGC-000B' started by Ether Dragan, Aug 16, 2017.
  1. Ether Dragan
    Ether Dragan Well-Known Member
    The Rowdy Ranger is very versatile.
    At long rang, using double Light Gauss is a pleasure.
    When targets has under 500 meter add the 3 ERMLas. You will don't have any heat management problem.
    For the Brawl, you mainly use UAC20 and LGauss.
    L Gauss have quite the same cooldown with UAC20 & ERMLas.
    After some practice, it's possible to shoot all and torse twiste.
    If you need a big burst of damage to finish a target, the 3 RL10 are your friend. It's interesting to use it if your UAC20 jammed at a very bad moment.
    The Heat efficiency is very good (2x LGauss + UAC20 = Heat neutral), and LGauss are effective for Sniping and usable for Brawl.
    RL10 is not mendatory, you can remove it to had some amnos or/and upgrade armor.
