Max Speed! Run Forrest, run! Alternative with Standard/Stock Engine: testrun: [img width=700 height=437]http://i39.tinypic.com/295wqd0.jpg[/img] Blagg
Been using a similar build to your second one. Been having a blast. Try using it as a light hunter once you get speed tweak. No lights around? No problem, keep other brawlers off your teammates, maybe flank because its great at hit and runs.
how does it do on ammo for the streaks? I've been using a X-5 with 2 ssrms and 1 ton of ammo and I find that I run out quick with all the lights that have been in game lately. Anyway it looks great and I'll be using it as soon as I get a xl360. edit: I've been using this some and it is a lot of fun. Not as fast or as easy to use as an X-5 for basically the same thing, but if someone doesn't want to spend MC this is a good choice.
Never really had issues with the ammo levels, usually I'm dead or the match ended when im halfway into my last ton.
Excellent build. I downgraded the engine slightly and ran like this. Performed beautifully. My very first match.
