Omnipod differences: [RT:C] [LT] Normally not a fan of jack-of-all-trades builds, but I did build one myself just now. With a 62.50 alpha. Right Side: 2x cERLL for longrange sniping and extra damage when heat allows. 2x cERML for precision in closer ranges. Left Side: 2x cERSL for brawling, they're basically IS MLs with a 180m range and shorter cooldown (the DPS is almost the same as an cERML) 2x cSRM4 for close range critseeking burst (due to the TC1) I suggest you don't swap around these weapon positions, so that you can eventually poke out only one side when you need to fire but you're pretty beat up. Lots of weapons require a lot of control groups, so let me help you out: 1: cERSL 2: cERML 3: cSRM4 4: cERLL Why do I choose this? Your left and right mouse click are the weapons you'll use most in a hectic brawl. thus, the cERSL and cERML (and their respective arms) are mapped here. I usually use the weapon group 3 for the burst weapon on a brawler build. Group 4 is for cERLL, which you'll mostly use at range or in extreme dire need. making it relatively harder to reach automatically means you'll not accidentally use it and overheat yourself in a normal battle, but only at range (where you don't need to react superquick) or when you're just pressing all buttons in the hope the enemy dies before you do.
do you think small pulse lasers would work effectively with this blagg? im kind of curious how much the targeting computer would help considering it extends the range and lowers time needed on target. as well as crit chances, the heat is still managable. its working decently for me so far. have a look.
4 ersml is a nice alternative , they sadly nerfed the damage from 5 to 4. Considering 1 DHS Vs a gain of 6 alpha (though the longer burn time should of course be considered ), I'd prefer the original variant
